i've tried to install wine-mono 4.7.1 on Lubuntu 17.10
wget http://dl.winehq.org/wine/wine-mono/4.7.1
sudo apt update
Result:
Hit:1 http://bg.archive.ubuntu.com/ubuntu artful InRelease
Get:2 http://bg.archive.ubuntu.com/ubuntu artful-updates InRelease [78,6 kB]
Get:3 http://bg.archive.ubuntu.com/ubuntu artful-backports InRelease [72,2 kB]
Get:4 http://security.ubuntu.com/ubuntu artful-security InRelease [78,6 kB]
Hit:5 http://download.mono-project.com/repo/ubuntu xenial InRelease
Hit:6 http://ppa.launchpad.net/cdemu/ppa/ubuntu artful InRelease
Ign:7 http://dl.winehq.org/wine/wine-mono/4.7.1 artful InRelease
Err:8 http://dl.winehq.org/wine/wine-mono/4.7.1 artful Release
404  Not Found
Hit:9 https://dl.winehq.org/wine-builds/ubuntu artful InRelease
Hit:10 http://deb.playonlinux.com trusty InRelease
Reading package lists... Done
E: The repository 'http://dl.winehq.org/wine/wine-mono/4.7.1 artful Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I look This post
The "sudo add-apt-repository --remove ppa:" command didn't work for me.
Tried manually remove from /etc/apt/sources.list but access is denied
Is there other way to remove the broken repository
Djugana
  • 93
The wget command does not add a ppa in the first place, it simply downloads files over http. The command you posted simply downloads Wine from the internet.
However, if you find you would like to remove a source manually, you can do so by opening /etc/apt/sources.list and removing the line that contains the source.
You can do this using the command sudo nano /etc/apt/sources.list. Sudo is used as you require root privileges to edit the file.
Tom
  • 188
-1
The command to download mono is:
wget https://dl.winehq.org/wine/wine-mono/4.7.1/wine-mono-4.7.1.msi
then you have to run it in the WINE prefix that you want to install mono in.
To correct the sources list, you need root privileges:
ravery
  • 6,924
