I'm running 17.04 LTS (upgraded from 16.04 a while a go).
Now and then again, audio seems to stop working for some reason. Sometimes I reboot and it starts to work again but this time it didn't. Annoyed as I am, I'm asking here to see if anyone can figure this one out.
I did tail -f /var/log/syslog while running pulseaudio -k to see what happens:
bluetoothd[1728]: Endpoint unregistered: sender=:1.278 path=/MediaEndpoint/A2DPSource
bluetoothd[1728]: Endpoint unregistered: sender=:1.278 path=/MediaEndpoint/A2DPSink
rtkit-daemon[1495]: Successfully made thread 4706 of process 4706 (n/a) owned by '1000' high priority at nice level -11.
rtkit-daemon[1495]: Supervising 1 threads of 1 processes of 1 users.
indicator-sound[2194]: volume-control-pulse.vala:735: unable to get pulse unix socket: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.PulseAudio1 was not provided by any .service
pulseaudio[4706]: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
pulseaudio[4706]: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="5" name="usb-M-Audio_Keystation_61-00" card_name="alsa_card.usb-M-Audio_Keystation_61-00" atency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
bluetoothd[1728]: Endpoint registered: sender=:1.354 path=/MediaEndpoint/A2DPSource
bluetoothd[1728]: Endpoint registered: sender=:1.354 path=/MediaEndpoint/A2DPSink
rtkit-daemon[1495]: Successfully made thread 4724 of process 4724 (n/a) owned by '1000' high priority at nice level -11.
rtkit-daemon[1495]: Supervising 2 threads of 2 processes of 1 users.
pulseaudio[4724]: [pulseaudio] pid.c: Daemon already running.
compiz[2363]: [1:21:1204/234141.860784:ERROR:webrtcsession.cc(345)] Failed to set remote answer sdp: Called in wrong state: STATE_INPROGRESS
compiz[2363]: [1:21:1204/234142.874344:ERROR:webrtcsession.cc(345)] Failed to set remote answer sdp: Called in wrong state: STATE_INPROGRESS
compiz[2363]: [1:21:1204/234142.875896:ERROR:webrtcsession.cc(1150)] ProcessIceMessage: ICE candidates can't be added without any remote session description.
compiz[2363]: [1:1:1204/234142.875937:ERROR:rtc_peer_connection_handler.cc(1575)] Error processing ICE candidate.
unity-settings-[2205]: Unable to get default sink
unity-settings-[2205]: Unable to get default source
I'm using two USB interfaces:
- Focusrite 6i6 USB Interface
- Behringer Xenyx Q502 USB Interface
Thanks in advance.
