So a few weeks ago I update to 17.10 and at pretty much the same time I updated to Android Studio 3, and it was probably a mistake updating both as now I don't know where the problem lies.
Basically it seems like disk IO has gotten really bad. At first I noticed I was swapping so I doubled my ram (32 gigs now) and I'm never swapping anymore. But the machine still pretty much freezes when disk IO happens. By freezes I mean it will get really slow, to the point that I can type and I won't see what I'm typing for a few seconds, often I'll get a long string of one key when that happens.
When I go to commit my code, Android Studio will do an analysis of the code and the UI just freezes while it does that. Takes a few seconds. None of these issues used to happen before updating both things.
Also, when the cloud station backup runs to my NAS, it gets ridiculously slow.
I have a Samsung SSD 850 PRO 512GB SSD.
So what can I run to see what the issue is?
Thanks.
Edit:
Smartctl output:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.13.0-16-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: Samsung SSD 850 PRO 512GB
Serial Number: S250NSAG809789J
LU WWN Device Id: 5 002538 8a0af305f
Firmware Version: EXM02B6Q
User Capacity: 512,110,190,592 bytes [512 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Nov 28 16:22:20 2017 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 272) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 23126
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 75
177 Wear_Leveling_Count 0x0013 098 098 000 Pre-fail Always - 117
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 070 057 000 Old_age Always - 30
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 34
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 37060089586
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
df -i output:
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 4096227 613 4095614 1% /dev
tmpfs 4111096 1024 4110072 1% /run
/dev/sda1 29908992 4301747 25607245 15% /
tmpfs 4111096 524 4110572 1% /dev/shm
tmpfs 4111096 5 4111091 1% /run/lock
tmpfs 4111096 18 4111078 1% /sys/fs/cgroup
tmpfs 4111096 17 4111079 1% /run/user/122
tmpfs 4111096 458 4110638 1% /run/user/1000
/home/mydir/.Private 29908992 4301747 25607245 15% /home/mydir
