For the specific case of window arrangements, there's a screen command to save them to a file: layout dump. From man screen:
layout dump [filename]
Write to a file the order of splits made in the current layout. This is
useful to recreate the order of your regions used in your current
layout. Only the current layout is recorded. While the order of the
regions are recorded, the sizes of those regions and which windows
correspond to which regions are not. If no filename is specified, the
default is layout-dump, saved in the directory that the screen process
was started in. If the file already exists, layout dump will append to
that file. As an example:
C-a : layout dump /home/user/.screenrc
will save or append the layout to the user's .screenrc file.
So, once you make the arrangement manually, press Ctrla:, then type layout dump /path/to/some/file. The layout will be saved to /path/to/some/file and you can then restore it in a new session with:
screen -c /path/to/some/file
