After a snap has been installed with sudo snap install [package] how can I list the files which have been installed by the snap?
- 6,519
Snaps are compressed squashfs files, which typically get 'installed' to /var/lib/snapd/snaps. So if you snap install ohmygiraffe you'll find a file called /var/lib/snapd/snaps/ohmygiraffe_3.snap.
If you'd never installed a snap before then you'll also have a core snap which lives at the same location.
If you're interested in seeing what's inside that snap, look in /snap/<snapname>/<current>/. Note that you're peering into the snap, the contents aren't unpacked onto your filesystem.
The only other thing you'll find is a .desktop file in /var/lib/snapd/desktop/applications.
Once your snap has been run, you may also find data in ~/snap/<snapname>.
- 24,549
Snaps are standalone squashfs images, which means listing what they install is as simple as listing the contents of the image. These images get mounted into place at /snap/<snapname>/<snap revision>, although you can just use /snap/<snapname>/current for the currently-active revision, e.g.:
$ ls -lR /snap/<snapname>/current/
- 7,502
If you don't have root and/or want to look at a package that isn't installed and so isn't in /var/lib/snapd/snaps, you can use
cd /some/dir/for/storing/snaps/
mkdir snapname
cd snapname/
snap download snapname
unsquashfs -l *.snap
where snapname is the name of some snap.
unsquashfs may be installed with sudo apt install squashfs-tools
- 113
