Ok, I installed a windows package that had some of the missing fonts in it, but still missing the Calibri font. Thanks a lot for the help. Meantime, I'm still stuck with some missing fonts :-))
You simply need to install ttf-mscorefonts-installer by opening a terminal (easiest way to do is pressing ctrl+alt+t) and typing:
sudo apt install ttf-mscorefonts-installer
After you typed in this command you will be prompted for your password which you should supply.
In some cases the installation will print out an error message about a font not being able to be accessed by _apt, means the install partially failed.
Then do the following line by line on terminal (lines beginning with # are comments and you can leave them out). You can copy the lines here with ctrl+c and paste them into the terminal by ctrl+shift+v but make sure you copy the whole line each time.
# create a temporary directory
cd "$TMP"
# check and download the fonts
awk '/Url/ {system("wget "$2)}' /usr/share/package-data-downloads/ttf-mscorefonts-installer
# re run the installation
sudo /usr/lib/msttcorefonts/update-ms-fonts "$TMP"/*
sudo touch /var/lib/update-notifier/package-data-downloads/ttf-mscorefonts-installer
# clean up the temporary directory
cd ..
rm -r "$TMP"
you can close the terminal now by clicking on the 'X' on its top-bar or by typing exit. The fonts should then be available within LibreOffice.
- 33,815
