10
I have on a Xubuntu 16.04 another Xubuntu 17 running in a VirtualBox. I have the bidirectional clipboard share activated and have also installed
sudo apt-get install virtualbox-guest-dkms
on the guest. But even after rebooting I can't copy/paste between the guest and host machine.
I am running Parcellite on the host,could that be a problem?
user8292439
  • 3,878
  • 32
  • 57
Jeno
  • 375
  • 14
  • 28
5 Answers5
14
You should install virtualbox-guest-x11 package as dkms installs only the drivers. Then run the command VBoxClient --clipboard.
Sources How to fix virtualbox's copy and paste to host-machine?
ob2
  • 3,653
The method with 'VBoxClient --clipboard' did not work for me.
So, I downgraded VirtualBox from verison 6.1.4 to 6.1.2 and the problem disappeared.
I did not get any response here and could not figure it out - tried many options (same problem with VMPlayer also).
But the good news, at least from cut-n-paste perspective, use an alternative client. You can use SSH to log into the machine using your favorite tool - PuTTY or even cmd will work. This actually is a better solution - no need to muck with mouse capture and all that.
  1. So just setup an SSH server:
    $ sudo apt update
    $ sudo apt install openssh-server
    $ sudo systemctl status ssh
    Active: active (running)
  2. Open firewall:
    sudo ufw allow ssh
  3. Check IP address:
    ip a
  4. SSH in with PuTTY or cmd or:
    ssh <username>@<ip_address>
You are done! It should work like a charm!
Note: This SSH works only from local host as the VM only has a private IP. If you can create a public IP on a VM (that is another arduous adventure - still working on it), you will be able to remote SSH.
Sam-T
  • 173
  • 13
Using latest Virtual Box 6.1 on Windows10 host, using Ubuntu 18.04 guest
First I had installed by downloading How To Install VirtualBox Guest Additions on Ubuntu 18.04
sudo apt install build-essential dkms linux-headers-$(uname -r)
sudo sh ./VBoxLinuxAdditions.run --nox11
The install was successful, It should have worked but didn't
Next I did (as suggested above):
sudo apt-get install virtualbox-guest-dkms virtualbox-guest-utils virtualbox-guest-x11
This also did not work, I have rebooted and all that, enabled bidirectional - clipboard, drag-n-drop, etc.
Not only cut-n-paste does not work, I cant even scroll my mouse pointer above the prompt - so essentially makes the VM useless.
You would expect something like this to work by default, but unfortunately not, even after all the hoops.
Sam-T
  • 173
  • 13
I just upgraded my VirtualBox to 6.1, and the Guest Additions on my Ubuntu guest to the corresponding version, and right now I think that this introduced a bug because my clipboard-sharing also stopped working ... as soon as I upgraded. (Yes, I installed the Additions both on the host and on my Ubuntu guest.)
Therefore, I'm pretty sure that this is Oracle's bug, and that we'll be seeing a hot-fix coming out from them in a few days.
