I have:
- VirtualBox - 6.1.4 r136177 (Qt5.6.2)
- Host: Windows - 10
- Guest: Ubuntu Desktop - 18.04 LTS
About VirtualBox having
SharedclipboardandDrag n Dropconfigured with bidirectionalExtension Pack6.1.4 r136177 installed
And the Guest Ubuntu having:
Guest Additionsinstalled
The Shared Clipboard feature does not work how is expected.
Ctrl + C+Ctrl + Vbetween Host/Guest and vice versa, right?
Confirm that they are the correct combination.
Because I tried with
Shift + Ctrl[left|right] + c-Shift + Ctrl[left|right] + vCtrl[left|right] + Shift + c-Ctrl[left|right] + Shift + v
and does not work
What is missing?
I read these links:
- Why doesn't clipboard sharing work with Ubuntu 18.04 LTS inside VirtualBox 5.1.26?
- VirtualBox shared clipboard does not work
Both do mention to install virtualbox-guest-x11
Assumption: of course, assuming it should enable in peace the shared clipboard feature.
Through the sudo apt search virtualbox command I got a list and I can see these two coincidences
virtualbox-guest-x11/bionic-updates 5.2.34-dfsg-0~ubuntu18.04.1 amd64
x86 virtualization solution - X11 guest utilities
virtualbox-guest-x11-hwe/bionic-updates 5.2.34-dfsg-0~ubuntu18.04.1 amd64
Working with the former, I tried but arises:
sudo apt install virtualbox-guest-x11
Reading package lists... Done
Building dependency tree
virtualbox-guest-x11 : Depends: xorg-video-abi-23
Depends: xserver-xorg-core (>= 2:1.18.99.901)
I am not a Linux/Ubuntu expert, my concern is avoid to create conflicts with VirtualBox - Guest Additions and virtualbox-guest-x11 mostly because their versions are not the same.
So I should go and install anyway that dependencies?
