My shot in the dark is based on this sentence: So, I've tried using sudo to run everything but it eventually crashes and errors at some point.
If you really do run everything by sudo probably the ownership to some files and folder in your user's home directory is changed to root:root, that causes a lot of errors. To check this, execute the following command and read the third and the fourth column (press q to exit):
ls -laR ~ | less
To recover from this situation execute:
sudo chown -R $USER:USER $HOME
This command will change recursively the ownership of /home/<user> to your user and :group.
The command sudo allows a permitted user to execute a command as the superuser (root). So you should be really careful when you using this command. The rule number one [read here]: don't use sudo with any graphical applications. It probably will cause the situation described above. If you have done this, maybe your downloaded files are located in /root/Downloads.
By the login option sudo -i you will be able to become root via your own credentials - username and password - if you are a permitted user. But to become root by the command su (switch user as I call it :) the root's account must be enabled, that is not recommended.
To install software packages on first place (as @Piloti suggested) use Ubuntu Software Center, find the application and click on the Install button. It will ask you for your password and if you are a permitted user, able to execute commands as root, the package will be installed.
If you already have downloaded any .deb package you could install it by double click on it and open with Ubuntu Software Center. You could install a .deb package also via the command line by the command dpkg -i. You should execute this command as root:
sudo dpkg -i <package name>.deb
You could install software packages via the command line directly from Ubuntu repositories by the command apt, that should be executed as root too. For example if you want to install Chromium browser execute the following command:
$ sudo apt install chromium-browser
[sudo] password for <user-name>: type your user's password here
