If I try to scan (xsane or simple-scan) I get this output:
Device URI: hpaio:/net/HP_LaserJet_MFP_M129-M134?hostname=hp-drucker
I was told that this device has great linux support ... See https://hardwarerecs.stackexchange.com/questions/8323/small-printerscanner-with-very-good-support-for-ubuntu
MIB search path: /home/guettli/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
Cannot find module (DISMAN-SCHEDULE-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-TYPES): At line 0 in (none)
Cannot find module (MTA-MIB): At line 0 in (none)
Cannot find module (NETWORK-SERVICES-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
Cannot find module (SNMPv2-SMI): At line 34 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Cannot find module (SNMPv2-TC): At line 37 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
.... (cut)
After updateing snmp packages I get this error now:
===> hp-scan
HP Linux Imaging and Printing System (ver. 3.16.11)
Scan Utility ver. 2.2
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
warning: No destinations specified. Adding 'file' destination by default.
Using device hpaio:/net/HP_LaserJet_MFP_M129-M134?hostname=NPIBC8C62.local
Opening connection to device...
error: SANE: Error during device I/O (code=9)
Still no scanning possible :-(
