df -h
gives:
Filesystem                         Size  Used Avail Use% Mounted on
udev                               3.9G     0  3.9G   0% /dev
tmpfs                              799M   81M  718M  11% /run
/dev/mapper/buildingbase--vg-root  287G   27G  246G  10% /
tmpfs                              3.9G     0  3.9G   0% /dev/shm
tmpfs                              5.0M     0  5.0M   0% /run/lock
tmpfs                              3.9G     0  3.9G   0% /sys/fs/cgroup
/dev/vda1                          472M  466M     0 100% /boot
/dev/vdb1                          2.0T  647G  1.4T  32% /mnt/bigstorage
tmpfs                              799M     0  799M   0% /run/user/1000
my kernel
uname -r
4.4.0-72-generic
And than my installed kernels...
dpkg -l | tail -n +6 | grep -E 'linux-image-[0-9]+'
as you can see NO OLDER KERNELS :-{
ii  linux-image-4.4.0-72-generic       4.4.0-72.93                                amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-75-generic       4.4.0-75.96                                amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-78-generic       4.4.0-78.99                                amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-79-generic       4.4.0-79.100                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-81-generic       4.4.0-81.104                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-83-generic       4.4.0-83.106                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-87-generic       4.4.0-87.110                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-89-generic       4.4.0-89.112                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-91-generic       4.4.0-91.114                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-92-generic       4.4.0-92.115                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
How can I clean up /boot?
Of course
sudo apt-get autoremove
is not working... not enough space
Zanna
  • 72,312
Niurbe
Apt's auto-removal logic assumes that you want newer kernels, and won't mark newer kernels as eligible for auto-removal
You are booted into the oldest kernel. Apt's auto-removal logic won't remove anything newer.
Your uptime must be impressive!
  1. Uninstall the kernels you are not using this will clean up your /boot:
    sudo dpkg --remove linux-image-4.4.0-{75,78,79,81,83,87,89,91,92}-generic linux-image-extra-4.4.0-{75,78,79,81,83,87,89,91,92}-generic
Now you must make a choice: Do you wish to resume upgrading your kernel regularly? Or do you wish stay on your current kernel for the life of your release? (It's not a permanent choice, you can always change.)
If you desire to get off the kernel-upgrade train entirely, use apt-hold to prevent newer kernels from being downloaded and installed. Then you can stop here and ignore the rest of this answer. This is not the recommended option for new or unskilled users. [thanks to @panther]
If you desire to continue upgrading kernels, then continue with the following steps. This is the recommended option for new or unskilled users.
  1. Update the kernel metapackages so they pull in the correct newest kernel
    sudo apt clean linux-image-generic linux-image-extra-generic
    sudo apt install --reinstall linux-image-generic linux-image-extra-generic
  2. Upgrade your system, which will pull in the latest kernel (-98) as well as test your package manager for proper function
    sudo apt update
    sudo apt upgrade
  3. Reboot into the new kernel. Rebooting monthly or even quarterly will prevent the problem from occurring again...or if you are a script guru, you can modify apt's auto-removal logic (it's just a script) to remove intermediate newer kernels.
    Alternately, if you dislike rebooting, try Ksplice. Ksplice is an update service that automatically applies patches to the Linux kernel without requiring a reboot of the computer. [thanks to @panther]
user535733
  • 68,493
sudo apt-get purge $(dpkg -l linux-{image,headers}-"[0-9]*" | awk '/ii/{print $2}' | grep -ve "$(uname -r | sed -r 's/-[a-z]+//')")
Use the above script. I have not used it in a while but it should work. This would remove all the kernel versions except for the one currently in use.
Legolas
  • 1,703
