I have an issue with my Sony Vaio SVE15128CXS laptop. Only when I choose to suspend it in the top right hand corner, or close the laptop to make it suspend, my keyboard stops working after resume.
I can only use the screen keyboard to login and after that, I have to save my work and restart the computer to use it normally.
It does not happen if I leave the computer on and it goes to sleep mode by itself.
How can I solve this issue?
Zanna
  • 72,312
Device: Sony Vaio E series
Solution to the problem which worked for me:
Edit /etc/default/grub using the command:
sudo -H gedit /etc/default/grub
and change the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash atkbd.reset"
Save the file and exit, then to make the change effective, run
sudo update-grub
and reboot.
Solution found here: Keyboard not working after suspend to ram (sleep)
Zanna
  • 72,312
