When using Firefox I have troubles with the use of Alt-Gr inside an open menu window (address bar, search bar, addon popup).
This is particularly annoying since, for instance, when using LastPass I cannot enter my email because the window gets closed as soon as I press Alt-Gr (I need it to type the @ sign).
I tried Safe Mode as well as previous Firefox versions, the problem doesn't fix.
The issue came out after updating some package (apt-get upgrade) I'm using Ubuntu 16.04, (with a Spanish keyboard layout)
How can I fix it?
cipricus
  • 4,066
  • 47
  • 106
FedFranz
  • 158
I post this as an answer for future reference.
The problem was probably due to a bug of the same LastPass addon, so it was automatically fixed with the following update.
In case this issue will happen again in the future, I suggest to downgrade the addon, or simply wait for the next update.
EDIT: Given the fact I suffered from the same issue (again) even without any addon installed, I must deduce the bug is actually within Firefox itself.
FedFranz
  • 158
The solution should be, to activate the checkbox Prevent accessibility services from accessing your browser in Firefox settings under Privacy & Security -> Permissions
Kare
