10
I need to convert all sheets of a single .xls/.xlsx file to a .csv. This will be done on all .xls files in all directories and sub-directories (recursively).
Step 1: Get the sheetnames of all .xls into a .csv using:
for file in $(find . -name '*.xls' -o -name '*.xlsx');do in2csv -n "$file" > ${file%.xls}-sheetnames-list.csv; done
filename-sheetnames-list.csv can act as a list:
sheetname1
sheetname2
sheetname3
Step 2 : The code for converting a specific sheet into a .csv using in2csv is:
in2csv --sheet "SHEETNAME" filename.xls > filename-SHEETNAME.csv
How can I get every sheetname in a .xls/x and write every sheet separately for all directories containing a .xls/x ?
in2csv --write-sheets "-" filename.xls > filename-sheet1.csv filename-sheet2.csv .... gives output only on sheet1.csv, not sure how to get all sheets from this.
csheth
  • 431
You can just put a loop inside another loop.
To avoid errors, don't use for with find results.
while IFS= read -r file; do
    while IFS= read -r sheet; do
        in2csv --sheet "$sheet" "$file" > "${file%.*}-${sheet}.csv"
    done < <(in2csv -n "$file")
done < <(find . -name '*.xls' -o -name '*.xlsx')
Eliah Kagan
  • 119,640
pLumo
  • 27,991
Skipping find and using bash:
shopt -s globstar  # enable recursive globbing
for f in **/*.xls{,x}  # for files ending in .xls or .xlsx
do
    in2csv -n "$f" |   # get the sheetnames
      xargs -I {} bash -c 'in2csv --sheet "$2" "$1" > "${1%.*}"-"$2".csv' _ "$f" {} # {} will be replaced with the sheetname
done
muru
  • 207,228
csvkit version > 1.0.2 has a builtin function to write all sheets:
--write-sheets: WRITE_SHEETS
                      The names of the Excel sheets to write to files, or
                      "-" to write all sheets.
So you could try the following:
find . -name '*.xls' -o -name '*.xlsx' -exec in2csv --write-sheets "-" {} \;
Note:
This seems not to work 100% as expected. But worth a try and as this is the first version with that option maybe in future versions the implementation is better/easier.
pLumo
  • 27,991
Use Gnumeric:
ssconvert -S filename.xlsx filename.csv
to get one csv file per sheet.
