Sure that it is a duplicate question of this list:
How do I resolve unmet dependencies after adding a PPA?
How to run 'apt-get install' to install all dependencies?
apt-get does not install dependencies
What does "packages have unmet dependecies" mean and what can I do about it?
Unable to correct problems, you have held broken packages
and many other, but, none works for me,
I have xubuntu Xenial 16.04
naively try to install texlive-latex-base so:
sudo apt-get install texlive-latex-base
 texlive-latex-base : Depends: texlive-base (>= 2015) but it is not going to be installed
                  Depends: texlive-binaries (>= 2015.20160222.37495-1) but it is not going to be installed
                  Recommends: texlive-latex-base-doc but it is not going to be installed
If the program can show the dependencies, so why it can not resolve?
Making some search: "apt install dependencies"
Then try:
sudo apt -f install texlive-latex-base
sudo apt-get -f install  texlive-latex-base
Also
sudo apt-get install -f
sudo apt-get build-dep build-essential
And get the same message.
Also try this sequence of commands:
sudo apt-get clean
sudo apt-get install -f -> 0 upgraded, 0 newly installed, 0 to remove and 258 not upgraded.
sudo dpkg --configure -a
sudo apt-get update
sudo apt-get upgrade -f
     The following packages will be upgraded:
     a lot of package but not texlive
     I respond with Yes
     and a lot of packages was dowloaded
And try again:
   and get the same message:
        bla bla
Then install Aptitude:
sudo aptitude -f install texlive-latex-base
respond with Y show
Need to get 0 B of archives. After unpacking 0 B will be used.
nothing happend
Then install Synaptic,when mark to install is show with red sign "!" that mean Broken status, search how to fix it, go Status, Broken dependencies, try to Mark for complete removal but it is disable.
What I am doing wrong?
