I'm getting below error when I run apt install gimp
Reading package lists... Done
Building dependency tree
   gimp : Depends: libgimp2.0 (>= 2.9.7~17-ubu16.04.2.2~ppa~9eb75cd) but it is not going to be installed
        Depends: libgimp2.0 (<= 2.9.7~17-z) but it is not going to be installed
        Depends: gimp-data (>= 2.9.7~17) but it is not going to be installed
        Depends: gimp-data (<= 2.9.7~17-z) but it is not going to be installed
        Depends: libgegl-0.3-0 (> 1:0.3.21~16) but it is not going to be installed
        Depends: libmypaint (>= 1.4.0~7-u16.04.1~ppa~c196a86) but it is not going to be installed
Edit: I've ended up installing gimp from Ubuntu Software.
0MF0
You must uninstall Gimp and remove the external Gimp PPA from software sources.
$ sudo apt remove gimp
Then open Software & Updates and remove the PPA from 'Other Software'.
After that, you can install a new clean instance of Gimp:
$ sudo apt update
$ sudo apt upgrade
$ sudo apt install gimp
cialu
  • 1,032
-1
I had a similar problem with BOINC Manager after an update a few weeks ago. The general form of my solution will likely fix your problem.
I dug through the dependencies of the package I was trying to install, then looked for other packages that depended on an older version of the same packages. That dependency (especially in the case where a newer version was listed as breaking the second package) prevented the installer from removing/upgrading the dependency, hence preventing installation of the desired package.
Fortunately, this kind of conflict in Ubuntu is likely to occur only in relatively uncommon packages or those that come from third party repositories, so it narrows the search. In my case, I had to choose between golly, a Life simulator, and BOINC Manager, which depended on and were broken by different versions of a GTK support library. I uninstalled golly and BOINC Manager installed and worked.
Find the conflicting library, and you'll find why GIMP won't install.
Zeiss Ikon
  • 5,248
