I have been trying to install Lamp server in my Ubuntu 17.04 machine for a couple of days. When i try to install it from the terminal i'm getting this error.
root@hp-pc:~# sudo apt install lamp-server^
Reading package lists... Done
Building dependency tree
Note, selecting 'libhttp-message-perl' for task 'lamp-server'
Note, selecting 'libencode-locale-perl' for task 'lamp-server'
Note, selecting 'mysql-client-5.7' for task 'lamp-server'
Note, selecting 'libevent-core-2.0-5' for task 'lamp-server'
Note, selecting 'libapache2-mod-php' for task 'lamp-server'
Note, selecting 'rename' for task 'lamp-server'
Note, selecting 'mysql-server-5.7' for task 'lamp-server'
Note, selecting 'php-common' for task 'lamp-server'
Note, selecting 'libaprutil1' for task 'lamp-server'
Note, selecting 'mysql-server' for task 'lamp-server'
Note, selecting 'libcgi-fast-perl' for task 'lamp-server'
Note, selecting 'libwrap0' for task 'lamp-server'
Note, selecting 'libhttp-date-perl' for task 'lamp-server'
Note, selecting 'perl-modules-5.24' for task 'lamp-server'
Note, selecting 'liblwp-mediatypes-perl' for task 'lamp-server'
Note, selecting 'libfcgi-perl' for task 'lamp-server'
Note, selecting 'libcgi-pm-perl' for task 'lamp-server'
Note, selecting 'libaprutil1-dbd-sqlite3' for task 'lamp-server'
Note, selecting 'libaio1' for task 'lamp-server'
Note, selecting 'libio-html-perl' for task 'lamp-server'
Note, selecting 'ssl-cert' for task 'lamp-server'
Note, selecting 'libperl5.24' for task 'lamp-server'
Note, selecting 'libapr1' for task 'lamp-server'
Note, selecting 'libaprutil1-ldap' for task 'lamp-server'
Note, selecting 'libhtml-tagset-perl' for task 'lamp-server'
Note, selecting 'mysql-client-core-5.7' for task 'lamp-server'
Note, selecting 'tcpd' for task 'lamp-server'
Note, selecting 'liblua5.2-0' for task 'lamp-server'
Note, selecting 'mysql-common' for task 'lamp-server'
Note, selecting 'libhtml-template-perl' for task 'lamp-server'
Note, selecting 'libtimedate-perl' for task 'lamp-server'
Note, selecting 'perl' for task 'lamp-server'
Note, selecting 'php-mysql' for task 'lamp-server'
Note, selecting 'libhtml-parser-perl' for task 'lamp-server'
Note, selecting 'liburi-perl' for task 'lamp-server'
Note, selecting 'mysql-server-core-5.7' for task 'lamp-server'
Note, selecting 'php7.0-mysql' for task 'lamp-server'
libaio1 is already the newest version (0.3.110-3).
libapache2-mod-php is already the newest version (1:7.0+49).
libapr1 is already the newest version (1.5.2-5).
libaprutil1 is already the newest version (1.5.4-3).
libaprutil1-dbd-sqlite3 is already the newest version (1.5.4-3).
libaprutil1-ldap is already the newest version (1.5.4-3).
libcgi-fast-perl is already the newest version (1:2.12-1).
libcgi-pm-perl is already the newest version (4.35-1).
libencode-locale-perl is already the newest version (1.05-1).
libevent-core-2.0-5 is already the newest version (2.0.21-stable-3).
libfcgi-perl is already the newest version (0.78-2).
libhtml-parser-perl is already the newest version (3.72-3).
libhtml-tagset-perl is already the newest version (3.20-3).
libhtml-template-perl is already the newest version (2.95-2).
libhttp-date-perl is already the newest version (6.02-1).
libhttp-message-perl is already the newest version (6.11-1).
libio-html-perl is already the newest version (1.001-1).
liblua5.2-0 is already the newest version (5.2.4-1.1build1).
liblwp-mediatypes-perl is already the newest version (6.02-1).
libperl5.24 is already the newest version (5.24.1-2ubuntu1).
libtimedate-perl is already the newest version (2.3000-2).
liburi-perl is already the newest version (1.71-1).
libwrap0 is already the newest version (7.6.q-26).
perl is already the newest version (5.24.1-2ubuntu1).
perl-modules-5.24 is already the newest version (5.24.1-2ubuntu1).
php-common is already the newest version (1:49).
rename is already the newest version (0.20-4).
ssl-cert is already the newest version (1.0.38).
tcpd is already the newest version (7.6.q-26).
 php7.0-mysql : Depends: php7.0-common (= 7.0.15-1ubuntu4) but 7.0.22-0ubuntu0.17.04.1 is to be installed
So i tried to install the package manually which shows unmet dependency
root@hp-pc:~# apt install php7.0-common
php7.0-common is already the newest version (7.0.22-0ubuntu0.17.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
As it says that package is already installed i tried to install php7.0-mysql manually.
root@hp-pc:~# apt install php7.0-mysql
To fix the held broken packages i tried the following commands.
root@hp-pc:~# sudo apt-get clean
root@hp-pc:~#
also
 root@hp-pc:~# sudo apt update
    Ign:1 http://ppa.launchpad.net/jonathonf/backports/ubuntu zesty InRelease
    Get:2 https://repo.skype.com/deb stable InRelease [4,487 B]
    Get:3 https://repo.skype.com/deb stable/main amd64 Packages [1,442 B]
    Hit:4 http://us.archive.ubuntu.com/ubuntu zesty InRelease
    Ign:5 http://ppa.launchpad.net/kirillshkrogalev/ffmpeg-next/ubuntu zesty InRelease
    Ign:6 http://dl.google.com/linux/chrome/deb stable InRelease
    Hit:7 http://dl.google.com/linux/chrome/deb stable Release
    Hit:8 http://ppa.launchpad.net/mozillateam/thunderbird-next/ubuntu zesty InRelease
    Hit:10 http://ppa.launchpad.net/obsproject/obs-studio/ubuntu zesty InRelease
    Hit:11 http://ppa.launchpad.net/papirus/papirus/ubuntu zesty InRelease
    Err:12 http://ppa.launchpad.net/jonathonf/backports/ubuntu zesty Release
      404  Not Found
    Err:13 http://ppa.launchpad.net/kirillshkrogalev/ffmpeg-next/ubuntu zesty Release
      404  Not Found
    E: The repository 'http://ppa.launchpad.net/jonathonf/backports/ubuntu zesty Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: The repository 'http://ppa.launchpad.net/kirillshkrogalev/ffmpeg-next/ubuntu zesty Release' does not have a Release file.
and this as well.
root@hp-pc:~# sudo apt-get upgrade
Calculating upgrade... Done
root@hp-pc:~#
root@hp-pc:~# sudo apt-get install -f
Still the issue is not fixed. Please advice.. thanks in advance. Also please note i have already gone through this answer.
Second Day
Managed to fix the previous error with the help of @zapoxkrishna. Now it showing the following error.
There is a MySQL server running, but we failed in our attempts to stop it.
Stop it yourself and try again!
dpkg: error processing archive /var/cache/apt/archives/mysql-server-5.7_5.7.20-0ubuntu0.17.04.1_amd64.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
I manually removed that file using rm command and tried to install again. Still getting the same error. Kindly advise.
Rooney
  • 975
Take the backup of your existing sources.list and try this sudo gedit /etc/apt/sources.list then delete the whole content and generate the new sources.list from here https://repogen.simplylinux.ch/ and paste the new generated content to sources.list
finally try this sudo apt-get update and then sudo apt install lamp-server^ it will work
