I had successfully been using Citrix ICA client 13.3 on Ubuntu 16.04 for quite a while. Recently I bought a new laptop and installed Ubuntu 17.10. I installed the latest 13.7 Citrix .deb, updated the SSL certificates etc and tried to login. However, I got some unfamiliar SSL error (4). After checking some forums I decided to try 13.4. I started off with
sudo apt-get remove icaclient
After that I installed the 13.4 deb. However, I got the same error and noticed there were still stray files left from 13.7, so I tried to completely remove them manually, as below
sudo rm -rf /etc/icaclient/
sudo rm -rf /etc/icalicense/
rm -rf ~/.ICAClient/
I then tried to reinstall 13.4 but it would not even load, complaining of missing .ini files (module.ini, regions.ini etc). I tried touching some and the receiver loaded, but of course complained about invalid keyboard mapping etc. I have come to the conclusion there are still some ICA files on my laptop and I need to delete them before proceeding. Can anyone tell me where they are?
After that, any tips fixing SSL error 4 on Ubuntu 17.10?
Thanks!
Try icaclient 13.6.
I had the same error with 13.7 and downgraded to 13.6. I don't have this issue with 13.6 anymore.
88weighed
  • 700
That is not needed. You can use the latest version just follow my answer here: Certificate error when using Citrix Receiver
Newer versions of the receiver require you to run their util and move the cert as a PEM certificate not the default CRT included with Mozilla ca-certificates.
Marlon
  • 916
Just succesfully installed the citrix client on a fresh ubuntu 17.10, using google chrome.
Download the Citrix Receiver for Linux from: https://www.citrix.com/downloads/citrix-receiver/linux/ Choose the debian packages, webclient only, architecture type depending on your cpu.
Install the package by clicking it (or from the command line if you prefer to type)
Add SSL certificates by executing the following two commands from the command line:
sudo ln -s /usr/share/ca-certificates/mozilla/* /opt/Citrix/ICAClient/keystore/cacerts/
sudo c_rehash /opt/Citrix/ICAClient/keystore/cacerts/
You can now use your webclient.
Resources: https://help.ubuntu.com/community/CitrixICAClientHowTo
The answer to my first question about removing orphan configuration files is to purge the package rather than simply remove it, e.g.
sudo dpkg -P icaclient
Then I tried 13.6 (didn't work). Then 13.4 (didn't work). Finally 13.3, which I had before (did work).
