I can't get the Citrix Receiver to work on Ubuntu 17.10. (SSL connection couldn't be established)
I tried different versions and copying the certificates from Mozilla as described here and here and ran ctx_rehash. Another answer suggests to convert a .crt file to .pem.
It's not clear to me though which file is meant and how to get it. I connected to citrix via browser (which works), exported the certificate from the page info/security, converted it to .pem and rehashed. Doesn't work though
unnic
You should simply re-use the certificates already installed with the ca-certificates package, e.g. (run these commands in your terminal)
cd /opt/Citrix/ICAClient/keystore/
sudo rm -r cacerts
sudo ln -s /etc/ssl/certs cacerts
No conversion and rehashing needed.
See Citrix receiver 13.10 on Ubuntu 18.04.1 for background reading (and why this is safe).
Peterino
  • 581
I'm having the same problem. And also tried to copy the certificates to /opt/Citrix/ICAClient/keystore/cacerts. I know the certificates work because I need them for browsing the internet (corporate firewall). Firefox and Chromium accept the certificates. Using openssl I found out that the certificates were already in pem format.
When making a connection to the Citrix storefront web page, I don't have a problem. The session starts fine.
edit:
The line below fixed it for me.
$ sudo c_rehash /opt/Citrix/ICAClient/keystore/cacerts/
I managed to connect by exporting the certificate manually from the browser:
  • go to the citrix site
  • view certificate
  • export the certificate. the correct one is one above the actual adress
  • convert from .crt to .pem
  • rehash
unnic
I encountered the same issue when using DoD card. I found this website, please look at comment from Jan 4, 2020 - as they have new information.
Shortly:
  1. Install pcsc
  2. Install openSC (both 1 and 2 from synaptic)
  3. In Firefox: preferences--> privacy&security --> Security devices --> load
Give name to your module. Then browse to /usr/lib/x86_64-linux-gnu/pkcs11/ and load the opensc-pkcs11.so file. After that things should work without an issue.
