I've moved from 17.04 to 17.10 (by update, not fresh install)
I have a bunch of customized .desktop files in my desktop.
When I try to run then, I get a message telling me these are "untrusted", and I have to retrust them manually.
Is there a way to trust them all?
note:
- desktop files have executable bit set (I have run
chmod +x). - before trusting they appear as a generic file, after with proper icon (e.g. terminal, browser, ...)
- worked fine before (that is icons and action were OK in 17.04)
- desktop to samba share are OK.
edit:
- files are not located in
/tmpneither in$HOME.
I have read :
Execute-Permission Bit Required
- Applications, including desktops and shells, must not run executable code from files when they are both: - lacking the executable bit - located in a user's home directory or temporary directory.
- my desktop are in neither of those.
- This includes *.desktop, *.jar, and *.exe files.
- .desktop files being
r--r--r--orr-xr-xr-xwon't execute.
- Nothing may provide a workaround to run them anyway automatically ...
Update
- 18.04 problem persist, accepted answer still work.
- 19.04 problem persist, accepted answer no longer work (you must replace yes by true, however after reboot,
.desktopnot executable) - 20.04 use
trueinstead ofyesin accepted answer, or right-click "allow execution" from desktop (this might be troublesome for generated.desktop)
