I have a system with multiple kernels installed and would like one of the kernels to boot up without the GUI/Desktop environment. I assume this can be done in the grub-customizer tool by editing the boot script for that specific kernel. Here's the script from the specific kernel I wish to modify:
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,$ else
search --no-floppy --fs-uuid --set=root 0c2ea0ab-08e3-42b6-8752-4b1aaad7bc1d
fi
echo 'Loading Linux 4.8.15-rt10 ...'
linux /boot/vmlinuz-4.8.15-rt10 root=UUID=0c2ea0ab-08e3-42b6-8752-4b1aaad7bc1d ro quiet splash 8250.nr_uart$ $vf_handoff
echo 'Loading initial ramdisk ...'
initrd /boot/initrd.img-4.8.15-rt10
Should I change gfxmode $linux_gfx_mode? If so, to what? Thanks
I also followed the last answer for this question, adding 'text' to GRUB_CMDLINE_LINUX_DEFAULT and uncommenting GRUB_TERMINAL="console".
I've figured out the command systemctl set-default multi-user.target forces console at boot and systemctl set-default graphical.target reverts back to GUI at boot, however, I want to implement this using a specific boot option. Is this possible?
