I recently got an Nvidia card, after long debating I convinced myself that I earned a little gaming - tho I only used the machine for webdev. so far I have no experience with gcards and ubuntu.
I installed the driver, or at least I tried. I got some problem with the nouveau kernel - so whatever stumbled upon this thread
How to disable Nouveau kernel driver
Did whats posted on the accepted answer and now the pc won´t start.
I got 2 Kernels in the Advanced Menu (4.10.0-35 and 4.10.0-37) but in the root bash I also do not get any eth device to work, so no way of sudo apt-get update / upgrade.
Tomorrow I can get an USB Stick with 17.04 Live on it, any quick way to fix that with the Live Image? Recovery? Will it keep my files - I got an Backup, but not from my databases. So it would be nice to fix it.
Is there a log where I can figure out where the problem is?
Isengo
  • 518
Had the same issue.
There is a way to boot with Ubuntu "live CD" or "Live USB stick", then select "Try Ubuntu".
When in, you can mount your "broken" system in terminal with:
sudo mount /dev/sda2 /mnt
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo chroot /mnt
now you can delete all the nvidia stuff and revert the blacklisting....
linuxmarc
  • 119
