I'm a newbbie on Ubuntu, and I'm having a lot of trouble trying to get Xampp or Lamp to work.
So I started trying to get Xampp, and I downloaded version 7.1.10, and I did everything I'm supposed to do: -ran chmod +x on the .run file, then I ran the file. The thing is, it installed in terminal(no interface opened like I saw in many videos), still, the installation ran smoothly. In the end, it said the setup completed sucessfully, and I went looking for the app everywhere but to no avail. I searched online but couldn't find anything that solved the problem.
So I uninstalled and installed several times, never worked.
Then I turned to Lamp. Again, setup the same way, thru terminal, in the end it even asked if I wanted to launch bitnami lamp stack, but then nothing happened. Again, no app, nothing.
So, any help would be greatly apreciated!(I'm running Ubuntu 17.10, maybe that's the problem somehow?)
Since 17.10 (Artful) version of Ubuntu, some applications seem to not work because of the "Wayland" server display. You may switch between Wayland/Xorg to make them work. This article explain in details how to : Installing and running XAMPP comfortably on Ubuntu 17.10
Veilleuse
  • 101
Xampp would usually get installed in /opt/lampp directory. Did you check the location?
Looks like it is related to this Why don't gksu/gksudo work with Wayland?
That's why you won't get the GUI.
But you can still use command line to manage it.
cd to /opt/lampp and use commands sudo ./xampp start and sudo ./xampp stop. You get list of possible commands with ./xampp
Legolas
  • 1,703
