I ran sudo apt-get install python-pip from terminal. But I got the following error :-
Reading package lists... Done
Building dependency tree
E: Unable to locate package python-pip
And when I ran the commmand sudo apt-get install python-setuptools python-dev build-essential. from terminal, I got the following error :-
E: Unable to locate package python-setuptools
E: Unable to locate package python-dev
E: Unable to locate package build-essential.
E: Couldn't find any package by glob 'build-essential.'
E: Couldn't find any package by regex 'build-essential.'
How do I solve this issue?
It seems that all Ubuntu repositories(main, universe, restricted, multiverse) are not enabled. That's why, you are getting Unable to locate <package> errors. To do it, run the following commands(one-by-one) from Terminal :-
sudo add-apt-repository main
sudo add-apt-repository universe
sudo add-apt-repository restricted
sudo add-apt-repository multiverse
sudo apt update
Also in the second command, i.e. sudo apt-get install python-setuptools python-dev build-essential., you didn't name the package build-essentialcorrectly. So you got this error :-
You can use a different method to install pip in Ubuntu 17.10. To do it, run the following commands(one-by-one) from Terminal :-
sudo apt install curl
curl https://bootstrap.pypa.io/get-pip.py -o /tmp/get-pip.py
sudo python3 /tmp/get-pip.py
pip install --user pipenv
echo "PATH=$HOME/.local/bin:$PATH" >> ~/.profile
source ~/.profile
References
Have you downloaded the apt package registry? Make sure you start with a $ sudo apt update, confirm you can get package updates with $ sudo apt update -y
Also, make sure your system isn't busted. Perhaps post your error messages? Can't install python-pip
