Possible Duplicate:
How do I increase the resize margin on windows?
When hovering near the edge of a window you get an option to resize them.
However that edge is too narrow when I'm using trackpoint or touchpad, making it difficult to hit the 'sweet spot'
Is there a way I can increase the width (respectively height) of the 'hot-zone' ?
Acebone
  • 155
You may like the keyboard shortcut as the easiest way to resize the window and totally avoid trying to grab the edge of the window! Try Alt-F8 then use either the keyboard arrow keys or your mouse/touchpad to resize the window.
Fisrt open your terminal and run:
sudo apt-get remove overlay-scrollbar liboverlay-scrollbar-0.1-0
Then restart. That would replace the new overlay scrollbars for the classic ones (that are more "handly")
If you want the new scrollbar back, open a terminal and run this:
sudo apt-get install overlay-scrollbar liboverlay-scrollbar-0.1-0
Hope it helps (:
iLQ
  • 446
