So recently I upgraded from xenial to zesty, trying to get more familiar with Ubuntu. I used to use arch so I regularly type sudo apt-get update && sudo apt-get upgrade to check for updates to any packages. But today I got a weird output:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  linux-headers-4.10.0-33 linux-headers-4.10.0-33-generic linux-image-4.10.0-33-generic
  linux-image-extra-4.10.0-33-generic linux-signed-image-4.10.0-33-generic
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
  cpp g++ gcc
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
I'm still unfortunately not very comfortable with apt-get so I decided to follow the instructions on this page but still haven't gotten it. I kind of tried doing a lot of the recommendations on the page but it still doesn't seem to work.
Here's what I've done so far and the various outputs I've gotten:
$ sudo apt-get install cpp
 cpp : Depends: cpp-6 (>= 6.3.0-9~) but it is not going to be installed
$ sudo apt-get install g++
distribution that some required packages have not yet been created or been moved out of Incoming.
 g++ : Depends: cpp (>= 4:6.3.0-2ubuntu1) but 4:5.3.1-1ubuntu1 is to
 be installed
       Depends: gcc (>= 4:6.3.0-2ubuntu1) but 4:5.3.1-1ubuntu1 is to be installed
       Depends: g++-6 (>= 6.3.0-9~) but it is not going to be installed
       Depends: gcc-6 (>= 6.3.0-9~) but it is not going to be installed
$ sudo apt-get install gcc
 gcc : Depends: cpp (>= 4:6.3.0-2ubuntu1) but 4:5.3.1-1ubuntu1 is to be installed
$ sudo cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 16.04.2 LTS _Xenial Xerus_ - Release amd64 (20170215.2)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://us.archive.ubuntu.com/ubuntu/ zesty main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ zesty restricted multiverse main universe #Added by software-properties
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://us.archive.ubuntu.com/ubuntu/ zesty-updates main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ zesty-updates restricted multiverse main universe #Added by software-properties
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ zesty universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial universe
deb http://us.archive.ubuntu.com/ubuntu/ zesty-updates universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://us.archive.ubuntu.com/ubuntu/ zesty multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://us.archive.ubuntu.com/ubuntu/ zesty-updates multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ zesty-backports main restricted universe multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ zesty-backports main restricted universe multiverse #Added by software-properties
# deb-src http://us.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://security.ubuntu.com/ubuntu zesty-security main restricted
deb-src http://security.ubuntu.com/ubuntu zesty-security restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu zesty-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu zesty-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb http://archive.canonical.com/ zesty partner
# deb-src http://archive.canonical.com/ xenial partner
# ll /etc/apt/sources.list.d/
total 8
drwx------ 2 root root 4096 Oct  6 19:26 ./
drwxr-xr-x 7 root root 4096 Oct  6 19:26 ../
$ sudo apt-cache policy cpp cpp-5
cpp:
  Installed: 4:5.3.1-1ubuntu1
  Candidate: 4:6.3.0-2ubuntu1
  Version table:
     4:6.3.0-2ubuntu1 500
        500 http://us.archive.ubuntu.com/ubuntu zesty/main amd64 Packages
 *** 4:5.3.1-1ubuntu1 100
        100 /var/lib/dpkg/status
cpp-5:
  Installed: 5.4.1-8ubuntu1
  Candidate: 5.4.1-8ubuntu1
  Version table:
 *** 5.4.1-8ubuntu1 500
Zeke
  • 101
