I have a Samsung scanner which hasn't been working since I installed 17.10.
# sane-find-scanner
found USB scanner (vendor=0x04e8 [Samsung Electronics Co., Ltd.], product=0x3430 [SCX-5635 Series]) at libusb:001:002
Each time I try to use simple-scan on 17.10, I get a crash.
$ simple-scan
Not a JPEG file: starts with 0xff 0xff
Same error (crash) with gscan2pdf
$ gscan2pdf
/usr/share/themes/Ambiance/gtk-2.0/apps/mate-panel.rc:30: error: invalid string constant "murrine-scrollbar", expected valid string constant
and same error with xscanimage
$ xscanimage
I think sane doesn't use the right driver
# scanimage -L
device `xerox_mfp:libusb:001:002' is a Samsung Samsung SCX-5635 Series multi-function peripheral
I have installed the driver from the Samsung website. New file /etc/sane.d/smfp-samsung.conf but seemingly the xerox driver is still being used.
In the xerox_mfp.conf there is well reference of the Samsung
So what's the problem? Bug in the xerox driver? Incorrect config?
Zanna
  • 72,312
Vincent
  • 138
Not connected with the scanner, but I found this question through searching on the "murrine-scrollbar" error.
This seems to trigger when opening any gui program from the terminal.
As reported in this bug report: https://bugs.launchpad.net/ubuntu/+source/sane-backends/+bug/1724078/comments/4 , edit the mentioned file at line 30, replacing murrine-scrollbar with scrollbar.
Samsung "is" Xerox for some devices. Do check if you are not affected by either: https://bugs.launchpad.net/ubuntu/+source/sane-backends/+bug/1728012 or https://bugs.launchpad.net/ubuntu/+source/sane-backends/+bug/1707352 and don't forget to let people know that you are affected too.
