I have a fresh install on a Dell XPS 13 and I followed these guides:
None of them allowed me to use the keyboard and trackpad in a normal fashion. I opted for disabling the touchpad and connecting a usb mouse.
I also found this: Problem installing libinput on 16.04.2
However, the libinput gives me this error:
sudo apt-get install xserver-xorg-input-libinput
Reading package lists... Done
Building dependency tree
 xserver-xorg-input-libinput : Depends: xorg-input-abi-22
                               Depends: xserver-xorg-core (>= 2:1.17.99.902)
And the solution listed there, this is to run
install xserver-xorg-input-libinput-hwe-16.04
and that broke my graphic environment and I had to boot in terminal mode and revert the step.
Has anyone here faced the same issue? I don't really wanna go back to Windows since I code a lot, also I've been using OS X for more than 10 years so sorry for any noobness in my question.
Many thanks in advance.
pachadotdev
  • 179
Currently I am on Elementary OS Loki. I had automated the fix of this problem by creating following shell script at /etc/X11/Xsession.d/56touchpadfix :
export `xinput list | grep -i touchpad | awk '{ print $6 }'`
xinput --set-prop "$id" "Synaptics Noise Cancellation" 20 20
xinput --set-prop "$id" "Synaptics Finger" 35 45 250
xinput --set-prop "$id" "Synaptics Scrolling Distance" 180 180
true
You need to tune values for your hardware. Mine work for Sony SVS series laptop. You may also want to try tuning other values listed by command : xinput --list-props "SynPS/2 Synaptics TouchPad"
Ganesh
  • 46
