git clone https://github.com/facebook/watchman.git
cd watchman/
git checkout v4.7.0
sudo apt-get install -y autoconf automake build-essential python-dev libtool libssl-dev
./autogen.sh
./configure
make
sudo make install
At the make step, I am getting the following error, which I assume means I cannot proceed with sudo make install.
make  all-am
make[1]: Entering directory '/home/jcovingt/watchman'
make[1]: *** No rule to make target 'thirdparty/tap.cpp', needed by
'thirdparty/libtap_a-tap.o'.  Stop.
make[1]: Leaving directory '/home/jcovingt/watchman'
Makefile:869: recipe for target 'all' failed
make: *** [all] Error 2
jerome
  • 837
User wez wrote on git about old version problem:
Sounds like you had previously built an old version in that clone of the repo. You can resolve this by running git clean -dfx to nuke all generated state, then re-run the installation instructions.
Take a look on:> https://github.com/facebook/watchman/issues/542
Filipe
It's fine, I just deleted the folder, re-cloned, and it worked just fine. I think I was running into issues trying to install v4.9.0. Installing at v4.7.0 seems ok.
jerome
  • 837
