Trying to install Watchman for React Native on a fresh install of Ubuntu 20.04.
I'm using the following steps (but if there's a better way of doing it - or if you can avoid using Watchman altogether I'd be interested to hear) ...
  git clone https://github.com/facebook/watchman.git -b v4.9.0 --depth 1
  cd watchman/
  git checkout
  ./autogen.sh
  ./configure --without-python --without-pcre --enable-lenient
  make
I get the error shown below during the 'make' step.
I've seen a number of questions related to building watchman but I haven't seen this situation.
tests/integration/cppclient.cpp: In function ‘int main(int, char**)’:
tests/integration/cppclient.cpp:114:12: error: ‘TimedOut’ does not name a type
  114 |    } catch(TimedOut& e) {
tests/integration/cppclient.cpp:120:12: error: ‘TimedOut’ does not name a type
  120 |    } catch(TimedOut& e) {
tests/integration/cppclient.cpp:25:9: warning: ignoring return value of ‘int system(const char*)’, declared with attribute warn_unused_result [-Wunused-result]
   25 |   system("rm -f hit");
tests/integration/cppclient.cpp:75:9: warning: ignoring return value of ‘int system(const char*)’, declared with attribute warn_unused_result [-Wunused-result]
   75 |   system("touch hit");
tests/integration/cppclient.cpp:88:9: warning: ignoring return value of ‘int system(const char*)’, declared with attribute warn_unused_result [-Wunused-result]
   88 |   system("rm hit");
make[1]: *** [Makefile:2766: tests/integration/cppclient_t-cppclient.o] Error 1
make[1]: Leaving directory '/home/rshea/src/watchman'
make: *** [Makefile:1264: all] Error 2
glaucon
  • 253
Simply install the same watchman 4.9.0 package from official repository by using below commands (and maybe consult with official guide):
sudo add-apt-repository universe
sudo apt-get update
sudo apt-get install watchman
If you are still sure about compilation - install dependencies and then compile the application using commands below:
sudo apt-get install git build-essential libtool libssl-dev pkg-config
cd ~/Downloads git clone https://github.com/facebook/watchman.git -b v4.9.0 --depth 1 cd watchman ./autogen.sh ./configure --without-python --without-pcre --enable-lenient make -j$(nproc) sudo make install
N0rbert
  • 103,263
You can use these commands
sudo apt update
Then run
sudo apt -y install watchman
https://installati.one/ubuntu/20.04/watchman/
