After installing it seemed to work fine for about a month, but then suddenly on a reboot it didn't turn on.
I had installed the driver by this method.
A similar problem seems to have been encountered by others here.
The fix listed didn't work for me though. I followed the instructions as follows:
I first opened both dkms.conf files:
sudo -H mousepad /usr/src/rtl8812au-4.3.8.12175.20140902+dfsg/dkms.conf
sudo -H mousepad /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/dkms.conf
Then I edited the fourth line of each so that it reads:
MAKE="'make' all KVER=${kernelver}"
Finally I tried to run dkms build:
sudo dkms build rtl8812au/4.3.8.12175.20140902+dfsg -k $(uname -r)
Which is when it outputs the following:
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....
'make' all KVER=4.10.0-35-generic........(bad exit status: 2)
ERROR: Cannot create report: [Errno 17] File exists:
'/var/crash/rtl8812au-dkms.0.crash'
Error! Bad return status for module build on kernel: 4.10.0-35-generic
(x86_64)
Consult /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/make.log for more information.
Details
Software and Updates currently reads like this.
lsusb shows that it is a recognized device:
Bus 001 Device 004: ID 13b1:003f Linksys WUSB6300 802.11a/b/g/n/ac
Wireless Adapter [Realtek RTL8812AU]
When I run:
sudo lshw -C network
I get the following:
*-network
description: Ethernet interface
product: 82579V Gigabit Network Connection
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: enp0s25
version: 05
serial: 00:22:4d:51:9b:2e
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.11-4 ip=192.168.0.194 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:35 memory:f3400000-f341ffff memory:f3425000-f3425fff ioport:3040(size=32)
dkms status gives me the following
dkms status
bbswitch, 0.8, 4.10.0-28-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-32-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-33-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-35-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-37-generic, x86_64: installed
bbswitch, 0.8, 4.4.0-93-generic, x86_64: installed
bbswitch, 0.8, 4.4.0-96-generic, x86_64: installed
nvidia-384, 384.90, 4.10.0-35-generic, x86_64: installed
nvidia-384, 384.90, 4.10.0-37-generic, x86_64: installed
rtl8812au, 4.3.8.12175.20140902+dfsg: added
Can anyone give me a hand? I'm sort of at a loss here.
Thank you so much in advance! If there is any other info I need to share to figure out a fix, please let me know.
