Problem
I had a Linksys WUSB 6300 dual-band USB WiFi adapter happily running on on my desktop PC with driver module 8812AU.
When I first got it to work I used the driver signing method to get it to work with Secure Boot. It worked fine with Kernel version 4.4.0-23-generic and later also with 4.4.0-24-generic where I resigned it after the update.
After the update to 4.4.0-28-generic resigning for some reason does not have the desired effect anymore and it does not seem to load the driver module 8812AU.
After updating to 4.4.0-38-generic the behavior remains the same.
The Additional Drivers tool now shows me this, so I am not sure if somehow the module files got messed up. I am pretty new to Ubuntu, so I wouldn't know how to tell. When it was still working it showed me this.
So in consequence the network adapter is not working and I am out of ideas what to check or do in order to get it back to work.
Details
lsusb shows me that the adapter is recognized as USB device:
Bus 002 Device 002: ID 13b1:003f Linksys WUSB6300 802.11a/b/g/n/ac Wireless Adapter [Realtek RTL8812AU]
sudo lshw -C network only shows me the Ethernet and the internal WiFi (it has a very similar name). It is an integrated WiFi adapter which is working poorly under Ubuntu and is thus not useful for me.
Note: 8821AE is the internal WiFi. I am trying to get 8812AU to run which is not listed here because it does not seem to be loaded.
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:03:00.0
   logical name: enp3s0
   version: 11
   serial: 54:a0:50:d5:4b:0b
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:42 ioport:e000(size=256) memory:f7d00000-f7d00fff memory:f0000000-f0003fff
*-network
   description: Wireless interface
   product: RTL8821AE 802.11ac PCIe Wireless Network Adapter
   physical id: 0
   bus info: pci@0000:04:00.0
   logical name: wlp4s0
   version: 00
   serial: 54:27:1e:d6:91:8d
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=rtl8821ae driverversion=4.4.0-22-generic firmware=N/A ip=192.168.0.20 latency=0 link=yes multicast=yes wireless=IEEE 802.11abgn
   resources: irq:46 ioport:d000(size=256) memory:f7c00000-f7c03fff
Running rfkill list all shows that nothing seems to be blocked:
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Any help would be greatly appreciated!
Many thanks.
mz1000
  • 73
This package can be fixed by editing the dkms.conf files...
sudo -H gedit /usr/src/rtl8812au-4.3.8.12175.20140902+dfsg/dkms.conf
Then change line 4 from MAKE="'make' all" to MAKE="'make' all KVER=${kernelver}"
Save and exit the editor then do the same with:
sudo -H gedit /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/dkms.conf
As a similar problem was reported on Ubuntu Forums and my edits have worked for the last kernel update I got.
For your current kernel you should be able to:
dkms build rtl8812au/4.3.8.12175.20140902+dfsg -k $(uname -r)
dkms install rtl8812au/4.3.8.12175.20140902+dfsg -k $(uname -r)
Reboot
Jeremy31
  • 13,293
Here is a quick script that I wrote to manually fix a broken rtl8812au-dkms driver issue that occurs after every kernel software update. Run the script with sudo after a kernel software update has occurred. The problem with this driver is that dkms builds it for the wrong kernel. It's a problem with dkms.conf, in the source code. I may have a permanent fix pending.
You can tell if you've got a kernel module load error in /var/log/syslog at boot time. In terminal, a modinfo 8812au will show vermagic as incorrect.
#!/bin/bash
# save as ~/Desktop/fix_8812au.sh
# in terminal: chmod +x ~/Desktop/fix_8812au.sh
# in terminal, run with: sudo ~/Desktop/fix_8812au.sh
cd /var/lib/dkms
# rtl8812au
dkms remove rtl8812au/4.3.8.12175.20140902+dfsg -k "$(uname -r)/$(uname -p)"
dkms build rtl8812au/4.3.8.12175.20140902+dfsg -k "$(uname -r)/$(uname -p)"
dkms install rtl8812au/4.3.8.12175.20140902+dfsg -k "$(uname -r)/$(uname -p)"
Update: the user was also using an older version of the 8812au driver, so we installed the current version of rtl8812au-dkms from the repositories, and it all worked. The script will be required immediately after the next kernel software update.
Update #2: the proper fix (thanks @Jeremy31) for this bug is to edit these two files:
gksudo gedit /usr/src/rtl8812au-4.3.8.12175.20140902+dfsg/dkms.conf
gksudo gedit /var/lib/dkms/rtl8812au/4.3.8.12175.20140902+dfsg/build/dkms.conf
and replace MAKE="'make' all" with this line:
MAKE[0]="'make' all KVER=${kernelver}"
heynnema
  • 73,649
I preach you should use kernel modules that are fully signed and compiled to the right version... then I sin and force a module in that I can't figure out how to sign (I'm security-challenged). Indeed before learning dkms I think I must have digressed and forced the wrong kernel version in before (but hey it still worked!).
You might find yourself in the same situation. Anyway using modprobe you can install an unsigned kernel module by adding these parameters:
-f, --force                 Force module insertion or removal.
                            implies --force-modversions and
                            --force-vermagic
    --force-modversion      Ignore module's version
    --force-vermagic        Ignore module's version magic
Of course I preach you should never do this, but then again....
