19
I use Kubuntu 17.04 with Auto Login. My Login password is different than my Keyring and Kwallet passwords. Each time I open Skype for Linux Beta 5.5.0.1 a dialog box opens saying
Enter password for keyring "default keyring" to unlock.
I enter the password and I can use Skype. I would like not to have to enter my password each time. I did some searching in Dolphin and found I have Ubuntu, Gnome and Python keyrings. I can find nothing in my applications or settings to access the keyring. I do have KDEwallet/Kwalletmanager. What can I do?
Some think this is caused by the presence of dbus-user-session
$ dbus-user-session --version
dbus-user-session: command not found
With Auto Login to Kubuntu enabled:
$ ps aux | grep keyring
user  1808  0.0  0.0  14288  1024 pts/1    S+   19:06   0:00 grep --color=auto keyring
With Auto Login disabled:
user  1258  0.0  0.1 203168  5152 ?        Sl   20:35   0:00 /usr/bin/gnome-keyring-daemon --daemonize --login
user  1856  0.0  0.0  14288   972 pts/1    S+   20:36   0:00 grep --color=auto keyring
6 Answers6
I've solved this problem as follows:
  1. In the Kubuntu launch menu, type password to find the utility Passwords and Keys. Open this utility.
  2. In the panel on the left you should see an entry Login in the section Passwords. Right click on Login, and select Change Password from the pop-up menu.
  3. You'll need to enter your current password first, then it asks for a new password
  4. Just leave the fields blank and press Continue.
Once you have done that, you should be able to open Skype without being prompted for the keyring password.
Obviously, this approach assumes you are fine with not having this extra layer of security on your keyring, but I expect for most home users this is perfectly fine.
For more info, look at http://ask.xmodulo.com/disable-entering-password-unlock-default-keyring.html
derHugo
  • 3,376
  • 34
  • 52
Tim T
  • 81
The situation in 18.04 - with solution:
  • the tool that triggers this is gnome-keyring, which came with the installation (from deb) of skypeforlinux; removing gnome-keyring is not normally possible (that is, with apt and such), as it would also remove Skype. (It can forcibly be removed, but that would lead to skypeforlinux being reported as broken, while sudo apt install -f will simply install gnome-keyring back.)
  • autologin disabled (in my case)
  • seahorse not installed
  • KDE Wallet disabled
  • when asked to enter the keyring password, click "Continue" until the prompt closes
  • at this point Skype starts but it may get stuck; it may even need to be killed from System Activity; after that, when started again it will log in normally, no keyring prompt anymore
I changed my login password to be the same as my keyring password (and my kdewallet password) and disabled auto login. I no longer need to enter my keyring password to open Skype (nor my kdewallet password to open other programs). For this system to take effect I needed to "quit Skype" (and not just close the window), shut down and boot again (The default option for Kubuntu to restart or shut down is to save the session. This can sometimes keep the applications of some settings. I changed my default to start with a new session). It seems to have a side effect that my Samba share on the network didn't work until I changed my network password to be the same as my keyring password.
When install or create an account, just press Cancel if skype requires a key ring. Next time if you log in, just click Cancel.
It is sufficient to install a key ring manager as SeaHorse: you will be prompted to the keyring password and next time Skype will autologin. Probably the first time you have to logout from Skype and relogin.
Fabio
I've installed skypeforlinux on Gentoo, so having these Gnome prompts showing up was a bit of surprise. For those coming from other distros getting here through search this is what I've figured. As a dependency skypeforlinux pulls in libsecret which pulls in gnome-keyring.
tl;dr If I understand it correctly after you login to skypeforlinux it stores access token to Microsoft servers into this keyring "thing", so next time you start skypeforlinux it just asks the keyring for the token so you don't need to relogin to skype. That is as long as the gnome-keyring-daemon is running and you did unlock the "Default keyring" in it using password when prompted at least once. What password it is? Well the one you created the Default keyring with. To me it was my Skype password (as Skype was the only app ever asking for it).
The actual keyring file we're talking about is stored in ~/.local/share/keyrings/Default_keyring.keyring and can be accessed using e.g. utility called seahorse.
The "thing" is not an anonymous password prompt anymore.
kub1x
  • 101
