23
I just installed MySQL-server and all of its dependencies, among other necessities. But when it went to configure mysql-server it failed to do so, and spit out an error. Which error is not relevant here as I managed to locate the problem as a dependency issue between mysql-server and mysql-common. Mysql-common needs to be removed.
But when I go to
apt-get purge remove mysql-common
It automatically wants to remove everything in association with it as well, including all mysql dependencies, even apache2 and php5..
So what argument needs to be added to apt-get command to uninstall ONLY ONE package, yet leave all others intact.
svick
  • 142
insomnia
  • 415
apt-get won't let you do that, since it's a potentially dangerous step for a package management system to allow.
As long as you are aware that there may be consequences, use dpkg with the --remove option to do it. For example:
sudo dpkg --remove mysql-common
Note: On my 12.04 system with apache2, php5, mysql-server installed separately, using apt-get to remove mysql-common DOES NOT want to remove apache2 or php5.
From insomnia's comment: If you need to override the dependency system's decision you can (with great care and making sure you know what you are doing) use an additional --force-depends.
sudo dpkg --remove --force-depends mysql-common
guntbert
  • 13,475
ish
  • 141,990
If anyone would like to know there 2014 debian command its:
dpkg --force-all -r name_of_package
Its changed a bit
There is alot of --force- arguments so for sake of depency better check them by:
dpkg --force-help
