UPDATE: None of the provided answer to this date (2017.10.16) have helped me solve the problem, so in a fair world no one should get the bounty. I should emphasis that the provided answer were either not in the direction of answering the question (like those who suggested installing Gnome) or their suggestion didn't work on the computer that I have this issue on. Nevertheless i appreciate the time and effort they have put into this.
This might look like a duplicate post but IT'S NOT since none of the suggestions and solutions in other posts worked in my case.
Problem description: Everything was going fine but I faces some sort of lags, so I rebooted the computer and after logging in to my account, Unity didn't load properly. I rebooted multiple times and ... Nothing.
What I did: I tried all the solutions and suggestion out there an none of the solutions out there worked. Things like:
the top 10 suggestions here: Unity doesn't load, no Launcher, no Dash appears
or
unity-tweak-tool --reset-unity
or
unity --reset-icons
or
unity --reset
or
gconftool --shutdown
sudo killall -r -I gconf
sudo killall -r -I dconf
rm -rf .compiz* .gconf* .config/dconf/ .config/compiz*
My Idea and question: Based on a suggestion of my friend, I tried to login with another user and it worked! everything was fine, which narrowed down that some settings in my account is corrupted!
The question is, Which files should I transfer from the other account that Unity works fine on to my own account?
When I try to run Unity from terminal I get the following:
$unity
unity-panel-service stop/waiting
unity7 stop/waiting
unity-panel-service start/running, process 6549
unity7 start/running, process 6648
Mehrad
  • 685
Assuming you can access the terminal, have you considered downloading and switching to another desktop environment? Recently I had a very similar problem with compiz/unity and the only solution was switching to GNOME 3. If you don't really care that much about the GUI, maybe that's the way to go.
So you can access your account and you can log into other accounts without any problem. I'm just guessing but maybe it's worth a try.
sudo apt-get install ubuntu-gnome-desktop
By the way, It can be a great moment to getting to know GNOME because the next LTS Ubuntu release will have it as default, from what I've heard.
pvaesrtdoe
  • 675
  • 18
Probably a disabled installation here at your desktop. You could try to solve this with:
sudo apt-get update
then
sudo apt-get install --reinstall lightdm ubuntu-desktop
It can happen that there appears a query, which display-manager you want to set as main display-manager ---> so simply choose then lightdm.
Hope this helps. Here you can find more explanations about lightdm:
https://wiki.ubuntu.com/LightDM
And here more explanations about unity:
https://wiki.ubuntu.com/unity
dschinn1001
  • 3,863
This just happens on my 16.04. These steps worked for me (credit to It's FOSS):
  1. Press Ctrl+Alt+F1 to access the console.
  2. Use your normal username and password to login.
  3. Type sudo apt update
  4. Type sudo apt install --reinstall ubuntu-desktop
  5. Type sudo shutdown -r now
Jaydin
  • 1,571
