I have en ext4 file system with a program that I run off of it. However, every time I boot my computer I have to remount the drive with the exec flag in order to run the application. How would I go about editing /etc/fstab to mount the drive with the exec flag by default instead?
Common permissions with Microsoft file systems in Linux
When mounting Microsoft file systems (NTFS and FAT) you set the permissions of all files and directories.
Individual permissions with Linux file systems
But with linux file systems (you have an ext4 file system) you can set and should set the permissions of files and directories individually.
When you create files in a directory they will inherit the permissions from the directory. So I suggest that you modify a directory, where you have your program(s) and shellscripts,
sudo chmod ugo+x /path-to/directory-name
This time, you have already your program file, so modify its permissions
sudo chmod ugo+x /path-to/program-name
Edit 1: You may also want to change the ownership of some directories and files individually, which is also possible and recommended in linux file systems.
sudo chown user:group /path-to/directory-name
and
sudo chown user:group /path-to/file-name
where user and group should be replaced by the actual user-ID and group-ID, that you want to own the file (the group-ID can be skipped, or set to the same as the user-ID).
Edit 2:
A line with mount option exec in fstab for a USB drive with ext4
It works for me (in Ubuntu 16.04 LTS as well as in Artful to become 17.10) to run executable files in ext4 file systems, when automounted as well as when mounted via /etc/fstab without the mount option exec.
But it is not the case for you. So I tested to add a line into /etc/fstab, with mount option exec (in Artful to become 17.10), and it works for me. I hope this will solve your problem.
Create a mountpoint
sudo mkdir -p /mnt/usb-ext4Identify the UUID of the partition in the USB drive to be mounted
sudo blkidUse the string without quotes.
Edit
/etc/fstabsudo nano /etc/fstabI added the following lines in my test
# external drive with ext4 partition UUID=984666a5-594c-4edc-93a9-8923e6f52c80 /mnt/usb-ext4 ext4 defaults,exec,errors=remount-ro 0 2
Edit 3:
Another line with mount options user,noauto,exec in fstab
When you add the line in the previous paragraph into fstab, the system wants the USB drive to be inserted. If you want to boot without it, you can get along if you add the mount options user,noauto to the option list in that line of fstab.
UUID=984666a5-594c-4edc-93a9-8923e6f52c80 /mnt/usb-ext4 ext4 user,noauto,exec,errors=remount-ro 0 2
But you have to initiate mounting afterwards, for example with
mount -L <label>
or
mount <mountpoint>
in my example
mount -L test-exec
or
mount /mnt/usb-ext4
The same user can unmount it
umount /mnt/usb-ext4
Test output
After rebooting I ran the following commands.
mtab:
$ grep /mnt/usb-ext4 ext4 /etc/mtab
/dev/sdb1 /mnt/usb-ext4 ext4 rw,relatime,errors=remount-ro,data=ordered 0 0
fstab:
$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
UUID=10880524-3839-4142-b7db-f65845d87825 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=E556-B809 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
I created a directory and changed ownership:
cd /mnt/usb-ext4
sudo mkdir bin
sudo chown $USER:$USER bin
Then I created a small shellscript and made it executable:
cd bin
echo 'echo Hello World'>hello
chmod ugo+x hello
Long list to check the permissions and ownership:
$ ls -l
totalt 4
-rwxrwxr-x 1 tester tester 17 okt 6 07:51 hello
and it can be run
$ ./hello
Hello World
General commands identifying the system
lsb_release:
tester@tester-SATELLITE-PRO-C850-19W:/mnt/usb-ext4/bin$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu Artful Aardvark (development branch)
Release: 17.10
Codename: artful
uname:
tester@tester-SATELLITE-PRO-C850-19W:/mnt/usb-ext4/bin$ uname -a
Linux tester-SATELLITE-PRO-C850-19W 4.13.0-12-generic #13-Ubuntu SMP Sat Sep 23 03:40:16 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
blkid:
tester@tester-SATELLITE-PRO-C850-19W:/mnt/usb-ext4/bin$ sudo blkid
/dev/sda1: UUID="E556-B809" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="b3276a58-ea15-4cea-8c74-095b13ea7aa6"
/dev/sda2: UUID="10880524-3839-4142-b7db-f65845d87825" TYPE="ext4" PARTUUID="d399063d-1c12-4a62-86d9-0112b15a3e40"
/dev/sdb1: LABEL="test-exec" UUID="984666a5-594c-4edc-93a9-8923e6f52c80" TYPE="ext4" PARTUUID="4b07dce4-4bde-4fe9-9b2f-2442a62b0b87"
lsblk:
tester@tester-SATELLITE-PRO-C850-19W:~$ sudo lsblk -fm
[sudo] lösenord för tester:
NAME FSTYPE LABEL UUID MOUNTPOINT SIZE OWNER GROUP MODE
sda 55,9G root disk brw-rw----
├─sda1 vfat E556-B809 /boot/efi 480M root disk brw-rw----
└─sda2 ext4 10880524-3839-4142-b7db-f65845d87825 / 55,4G root disk brw-rw----
sdb 30,2G root disk brw-rw----
└─sdb1 ext4 test-exec 984666a5-594c-4edc-93a9-8923e6f52c80 /mnt/usb-ext4 30,2G root disk brw-rw----
sr0 1024M root cdrom brw-rw----
- 47,684
Here's how I forced my Ubuntu 16.04.3 system to mount a thing with the default options, read man mount, especially the parts about "FILESYSTEM INDEPENDENT MOUNT OPTIONS" and "Mount options for fat".
I did
w3@aardvark:~(0)$ sudo lsblk --output "NAME,UUID,PARTUUID,SIZE,STATE"
NAME UUID PARTUUID SIZE STATE
sda 465.8G running
├─sda1 362254e8-2b99-442d-8ad9-4a348bc08032 ab519d4e-b282-4ca4-87a4-c3e5b143291f 111.3G
└─sda2 191289bd-73e0-4935-8f17-700559c83570 0109ac9a-7539-4323-9f1a-b24c59066e46 354.5G
sdb 465.8G running
├─sdb1 000a3a79-01 7.5G
│ └─cryptswap1 022bb8c1-4a34-444c-a359-b0aef01e3191 7.5G running
├─sdb2 000a3a79-02 1K
├─sdb5 83a64b80-5a37-4659-b797-221b88ef41f8 000a3a79-05 165.2G
└─sdb6 12817b99-9d2b-4357-a4ca-c11eab672a20 000a3a79-06 293G
sdc 0123-4567 3.7G running
sdd 0123-4567 7.4G running
sdf 931.5G running
└─sdf1 ff359af0-d996-4949-b27e-f24ce453c48c 00051704-01 931.5G
sdi F440-F7F4 3.7G running
I picked sdi for this example, YMMV
w3@aardvark:~(0)$ mount | grep /dev/sdi
/dev/sdi on /home/w3/mnt/mp3/OTHER type vfat (rw,nosuid,nodev,relatime,uid=1003,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro)
echo -e to force interpretating of \t, \n, select the options you like
w3@aardvark:~(0)$ echo -e "# Added by $USER $(date)\nUUID=F440-F7F4 /home/w3/mnt/mp3/OTHER\tvfat rw,exec,nosuid,nodev,relatime,uid=1003,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro 0 0"
# Added by w3 Fri Oct 6 00:35:20 EDT 2017
UUID=F440-F7F4 /home/w3/mnt/mp3/OTHER vfat rw,exec,nosuid,nodev,relatime,uid=1003,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro 0 0
w3@aardvark:~(0)$ !! | sudo tee -a /etc/fstab
echo -e "# Added by $USER $(date)\nUUID=F440-F7F4 /home/w3/mnt/mp3/OTHER\tvfat rw,exec,nosuid,nodev,relatime,uid=1003,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro 0 0" | sudo tee -a /etc/fstab
# Added by w3 Fri Oct 6 00:35:40 EDT 2017
UUID=F440-F7F4 /home/w3/mnt/mp3/OTHER vfat rw,nosuid,nodev,relatime,uid=1003,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro 0 0
This is good for the FIRST time. Subsequently, you can edit /etc/fstab with
sudoedit /etc/fstab
Be very careful, keep a backup copy of the last working fstab. If you break fstab your system will not work.
- 5,669
- 37,856
