I have a new clean install of 18.04.01 on hardware that was running Fedora 29 just fine. I had trouble with the iommu settings causing the usb ports to not work at all. Not even mouse and keyboard. Resolved that except that the usb 3.0 ports seem cranky. I have a Kingwin dock with a 1 terrabyte drive plugged into a USB 3.0 port that works just fine. It comes up in drive folder and mounts OK and I can access the entire drive. But then I connect a Samsung 64 gig 3.0 flash drive and it comes up but I get an error "Unknown file system exfat". I tried this with a Sandisk 3.0 flash drive and got the same error. I tried both drives in the same port that the Kingwin was plugged into. Very erratic behaviour. I tried apt-get install extfat-fuse extfat-utils no errors. I rebooted but the weird behaviour continues. Any ideas?
Asked
Active
Viewed 1,157 times
The error "Unknown file system exfat" is about the file system, not about USB 3.
There are two ways to go,
Work around the problem by replacing the Microsoft proprietary file system
exfatwith another Microsoft file system,FAT32or NTFS, or with the linux file systemext4or with UDF.Add the software necessary to manage the
exfatfile system. In my Lubuntu 18.04.1 LTS I have installed two program packages from the repository 'universe', which is there in installed Ubuntu systems,sudo apt update sudo apt install exfat-fuse exfat-utils
This AskUbuntu link will add some details about exfat and available alternatives.
Maybe there are problems with mounting the drive. In that case maybe this link may help.
sudodus
- 47,684
