I am using Python 3.6.2 on Ubuntu 16.04. On all prior versions of Python, I have never had this issue. I have googled around. There is no post on AskUbuntu on this specific issue that I could find. There is one on SO, but it is pretty old. I don't have etc/pythonstart as the accepted answer suggests and this is the ONLY place I've found that even references such a thing.
This SO answer is also old, but when I tried the solution:
malikarumi@Tetuoan2:~$ apt-get libreadline-dev
E: Invalid operation libreadline-dev
malikarumi@Tetuoan2:~$ sudo apt-get libreadline-dev
[sudo] password for malikarumi:
malikarumi@Tetuoan2:~$ apt-get readline
E: Invalid operation readline
malikarumi@Tetuoan2:~$ sudo apt-get readline
I do have the GNU Readline Library, up to 6, in usr/share/doc, so I don't know why that's not working for me since, as I said, I never had this issue on <3.6
So since this seems more like a OS issue than a Python one, I decided to post here. Suggestions? And let me know if the rebuild is still necessary. Thanks.
Installing gnureadline package instead of readline one solved my problem
pip install gnureadline
https://stackoverflow.com/a/44210086/12562703
As you said in comments, fixing the command to install the libreadline-dev package as suggested by the post on SO you linked seems to have solved your problem.
Here is the correct command again:
sudo apt install libreadline-dev
Byte Commander
  • 110,243
I believe this question has been addressed on SO. Aside from libreadline-dev, you may need to run sudo pip install readline
https://stackoverflow.com/questions/893053/seeing-escape-characters-when-pressing-the-arrow-keys-in-python-shell
Jon
  • 340
