My /boot/ partition is full and I can't purge old kernels, I've been trying the suggestions here but no luck How do I free up more space in /boot?
dpkg -l linux-image-\* | grep ^ii
ii  linux-image-4.4.0-71-generic       4.4.0-71.92  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-72-generic       4.4.0-72.93  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-75-generic       4.4.0-75.96  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-78-generic       4.4.0-78.99  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-79-generic       4.4.0-79.100 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-81-generic       4.4.0-81.104 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-83-generic       4.4.0-83.106 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-87-generic       4.4.0-87.110 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-89-generic       4.4.0-89.112 amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-71-generic 4.4.0-71.92  amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-72-generic 4.4.0-72.93  amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-75-generic 4.4.0-75.96  amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-78-generic 4.4.0-78.99  amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-79-generic 4.4.0-79.100 amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-81-generic 4.4.0-81.104 amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-83-generic 4.4.0-83.106 amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-87-generic 4.4.0-87.110 amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
sudo apt-get update suggests I Try 'apt-get -f install' with no packages (or specify a solution).
All I get for my efforts is this:
The following packages have unmet dependencies.
 linux-image-extra-4.4.0-93-generic : Depends: linux-image-4.4.0-93-generic but it is not going to be installed
 linux-image-extra-4.4.0-96-generic : Depends: linux-image-4.4.0-96-generic but it is not going to be installed
 linux-image-generic : Depends: linux-image-4.4.0-96-generic but it is not going to be installed
                       Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
sudo apt-get autoremove returns
Reading package lists... Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these.
 linux-image-extra-4.4.0-93-generic : Depends: linux-image-4.4.0-93-generic but it is not installed
 linux-image-extra-4.4.0-96-generic : Depends: linux-image-4.4.0-96-generic but it is not installed
 linux-image-generic : Depends: linux-image-4.4.0-96-generic but it is not installed
                       Recommends: thermald but it is not installed
E: Unmet dependencies. Try using -f.
apt-get autoremove.
As you worked out yourself, you will have to remove an old kernel manually first.
After running apt-get autoremove, your boot partition should be much emptier. I personally have a root cron to do that weekly so I don't get into your situation.
Make sure you do an update and upgrade too to resolve the dependency issues, then reboot to start the new kernel.
Scruffy
  • 111
Once you have run out of space and have half installed packages, apt gives up. You have to remove some packages with sudo dpkg -r xxxxx to get some free space, then you can have apt remove more.
psusi
  • 38,031
