I've successfully paired my BT Stereo headset that presents both A2DP and HSP/HFP profiles. However, by default, it starts with HSP/HFP profile active (I do can change it in Sound Settings manually). The questions are about introducing some automated behavior: - is there any method to force A2DP as default profile instead of HSP/HSF ? - is there any method to set this BT device as default audio sink once it is connected? Now I need manually select the BT device every time I connect it, to let Ubuntu apps use it, the default is laptop speakers (Built-in Audio).
I wish it could work as in case of Windows/MacOS where whenever you connect the BT headset, it becomes default device and default profile for audio playback is A2DP rather than HSP/HFP.
Thanks in advance,
P.
P.S. The headset is DENON AH-GC20, Ubuntu 17.04
