29
I tried to convert a file with pacpl, but I get the well-known "256" error. With the -v flag, the FAQ of pacpl tells me:
"The file you are trying to convert is a lossless .m4a file. The format is not yet supported by FAAC/FAAD."
Since faac/faad seems to be used in every other converting tool on Ubuntu, how can I successfully convert formats?
6 Answers6
32
You can convert an m4a file to flac with the ffmpeg command-line tool:
To install ffmpeg:
sudo apt-get install ffmpeg
To convert:
ffmpeg -i filein.m4a -f flac fileout.flac
To batch convert:
for i in $(find . -type f -name "*.m4a"); do echo "Converting $i to flac"; ffmpeg -i "$i" -c:a flac "${i%.m4a}.flac"; done
karel
  • 122,292
  • 133
  • 301
  • 332
duffydack
  • 7,584
13
sudo aptitude install libav-tools
for file in *.m4a; do avconv -i "$file" -f flac "`basename "$file" .m4a`.flac"; done
While both the answers involving ffmpeg/avconv (which I think are essentially the same tool) both work, they currently have a flaw. Namely that lossless m4a is often 24 bit sample, and currently ffmpeg/avconv will generally force the conversion to end up in 16 bit sample.
I believe using sndfile-convert (libsndfile) does not have this problem. Likewise, I believe it can be avoided by using mplayer to decode the m4a before encoding it with ffmpeg or flac. I think soundKonverter on KDE may do this for you.
In any case, whatever you do, I suggest checking whether the original and the converted file have the same bit depth of samples.
SKhan
  • 41
Personally I use this code. for file in *.m4a; do fname=$(basename "$file" .m4a); ffmpeg -i "$file" -vn -ar 48000 -f flac "$fname".flac; done.
So the output file don't have *.m4a.flac as extension.
And this is the ouput from ffprobe on a flac file:
Stream #0:0: Audio: flac, 48000 Hz, stereo, s32 (24 bit)
And don't forget to check the tags/metadata on the file. I was surprised to see my mail address in the tag/metadata. And ffprobe show more mtag/metada as Easytag.
thanks to zetdotpi and https://stackoverflow.com/a/2664758
Jay
Just combining all the useful information from the other three answers.
To check the bit depth on your mp4 files:
# cd into desired directory then...
ffprobe -show_streams ./[pick one file to test].m4a | grep -e codec_name -e bits_per_raw_sample
This should show the bit depth at the bottom of the output.
To use ffmpeg and for all files in a folder (assuming they are not 24 bit (or higher)):
for file in *.m4a ; do ffmpeg -i "$file" -f flac "$( basename "$file" .m4a ).flac" ; done
Hope that helps.
JamesIsIn
  • 309
Find all file with m4a extensions (works when filename as space or a new line) and convert codec using ffmpeg:
 find . -type f -name "*.m4a" -print0 | xargs -0 -I "{}" bash -c 'ffmpeg -i "$1" -c:a flac "${1%.m4a}.flac"' _ "{}" \;
Porcupine
  • 739
