Note: I am using the Gnome desktop environment
My laptop keyboard has only the keys it needs, and few of the normal compose keys available. I use them all. I'd like to set the compose key to End, but it's not on the list in Gnome Tweak Tool:
How can I set the compose key to End?
muru
  • 207,228
Nonny Moose
  • 2,315
I solved the problem with help from @chaskes:
xmodmap -e "keycode 115 = Multi_key End"
remapped the first level of End to the compose key, but allows me to press Shift-End to send an actual End keypress. I made this permanent by putting it in my ~/.xinitrc.
Other sources:
https://unix.stackexchange.com/a/109472/
https://askubuntu.com/a/24930/
Nonny Moose
  • 2,315
On my system, the insert key is totally useless. Touching it could only create typing errors. And the name makes sense for a Compose key.
xev told me that the insert key is keycode 118.
So my ~/.xmodmap is 2 lines:
keycode 118 = Multi_key
! Insert key is Compose key.
And for backup, I execute this in my startup file:
xmodmap -e "keycode 118 = Multi_key"
I don't really know if both changes were necessary, but it works perfectly and I don't feel like messing with it.
RickyS
  • 31
