I want completion like in emacs that if there is only a sole completion to the command you are typing, than you don't need to type it all.
For example:
package ins
is enough instead of typing the whole:
package install
Is there a package or script that does that?
I am looking for a solution that doesn't require hitting the tab key but rather hitting the enter straight away and having a script do the auto completion before running the command.
Eden K
You need to install bash-completion. If already installed, you need to source it:
source /etc/bash_completion
You can add it in your .bashrc file. You can add custom completions in /etc/bash_completion.d/
Carl
  • 744
bash does that by default if the bash-completion package is installed, just type e.g.
> apt i
press Tab ↹ and you'll get
> apt install
If there are multiple matches, pressing Tab ↹ another time will display a list of them., e.g.
> ap
Tab ↹
nothing happens
Tab ↹
aplay                         apport-bug                    apt                           aptdcon                       aptitude-curses
aplaymidi                     apport-cli                    apt-add-repository            apt-extracttemplates          aptitude-run-state-bundle
apm_available                 apport-collect                apt-cache                     apt-ftparchive                apt-key
apparmor_parser               apport-unpack                 apt-cdrom                     apt-get                       apt-mark
apparmor_status               appres                        apt-config                    aptitude                      apt-sortpkgs
applygnupgdefaults            apropos                       aptd                          aptitude-create-state-bundle
dessert
  • 40,956
I believe fish shell would be in order here. To install:
  1. Download from here
  2. Then use this tutorial to assist you learning.
George Udosen
  • 37,534
If your problem is you want Bash Completion, please refer to the post Terminal autocomplete doesn't work properly, else if you need Enter become as like Tab ↹ and also execute that command immediately, then you need to add the command below in your ~/.bashrc and then source ~/.bashrc it.
bind 'RET:"\C-i\C-j"'
The RET is shortened for RETURN; You could use "\C-M" instead as well which is stands for Ctrl+M.
αғsнιη
  • 36,350
