-1
Possible Duplicate:
Dash search gives no result
The dash home button brings up a panel that is greyed out, but it is totally empty.
It seems to be the very same issue as this: Dash home button brings up blank window which is unanswered.
/usr/lib/nux/unity_support_test -p returns
OpenGL vendor string:   X.Org R300 Project
OpenGL renderer string: Gallium 0.4 on ATI RV370
OpenGL version string:  2.1 Mesa 7.11
Not software rendered:    yes
Not blacklisted:          yes
GLX fbconfig:             yes
GLX texture from pixmap:  yes
GL npot or rect textures: yes
GL vertex program:        yes
GL fragment program:      yes
GL vertex buffer object:  yes
GL framebuffer object:    yes
GL version is 1.4+:       yes
Unity 3D supported:       yes
I've tried a unity --reset but that doesn't seem to work. Unity seems to reset, but I get the following warning over and over: cs space validation failed unity
What should I do next to try and fix this?
Edit: Attempted fixes: I've refomatted, did not work. I've done apt-get remove unity then apt-get update then apt-get install unity, did not work.
I've switched to Unity 2d and this seems to work. How can I get regualar Unity working or atleast find the error?
@shantanu How would I reinstall this? I can do an apt-get remove unity, then apt-get install unity? I did a complete reformat to make sure that it wasn't a one time thing but it's still happening.
@sanjayasanjuubuntu I need a reputation of 10 to post images on this site, but here is a link. http://s13.postimage.org/t9m0rirxz/Screenshot.png
