I just installed Ubuntu 12.04 on my wifes Dell Inspiron 1501, which uses an R300 ATI graphics chip. Neither the Dash or HUD appear when pushing the appropriate key. When I try unity --reset & in the terminal, I see that over and over it's spitting out:
r300: CS space validation failed. (not enough memory?) Skipping rendering.
This is just after starting Ubuntu with no apps open, so I find it hard to believe that just rendering the Dash / HUD is completely blowing out the VRAM. Any suggestions on getting this working?
/usr/lib/nux/unity_support_test -p
shows
OpenGL vendor string: X.Org R300
Project OpenGL renderer string: Gallium 0.4 on ATI RS480
OpenGL version string: 2.1 Mesa 8.0.2
Not software rendered: yes
Not blacklisted: yes
GLX fbconfig: yes
GLX texture from pixmap: yes
GL npot or rect textures: yes
GL vertex program: yes
GL fragment program: yes
GL vertex buffer object: yes
GL framebuffer object: yes
GL version is 1.4+: yes
Unity 3D supported: yes
All sections say "YES"
Rinzwind
  • 309,379
Ubuntiac
The Unity 2d desktop might fix this issue,
You can Access Unity 2D at the LighDM log in screen (only if you have automatic login disabled).
stephenmyall
  • 9,885
Isaac
  • 693
I had the same problem, tried countless things, and using Unity 2D it indeed fixed the problem.
This was on a Dell Dimension e510. Clicking on the Dash icon did not display the Dash window, but if I typed (invisibly) 'terminal' and pressed Enter, a terminal opened.
unity --reset is suggested elsewhere, and this produces endless r300 errors as the initial post described. With Unity 2D, it works fine.
RolandiXor
  • 51,797
Vanyo
