I have Ubuntu 16.04. I cannot see any wifi enabling option. I have selected the Broadcom driver in software and update, and the Wi-Fi switch is enabled in the BIOS.
I've looked through the help pages and run the following:
$ sudo lshw -C network
*-network
description: Network controller
product: BCM4311 802.11b/g WLAN
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:0b:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=b43-pci-bridge latency=0
resources: irq:16 memory:efdfc000-efdfffff
*-network
description: Ethernet interface
product: BCM4401-B0 100Base-TX
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth0
version: 02
serial: 00:1d:09:b6:10:83
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=b44 driverversion=2.0 duplex=full ip=192.168.1.135 latency=64 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:17 memory:ef9fe000-ef9fffff*
What should I do?
$ lspci -knn | grep Net -A3; rfkill list
0b:00.0 Network controller [0280]: Broadcom Limited BCM4311 802.11b/g WLAN [14e4:4311] (rev 01)
Subsystem: Dell Wireless 1390 WLAN Mini-Card [1028:0007]
Kernel driver in use: b43-pci-bridge
Kernel modules: ssb, wl
