I have tried every single step of the suggested solution mentioned for this issue, the main problem is that the commands didnt work :
Run in terminal
sudo dpkg -i b43-fwcutter_015-9_amd64.deb
tar xfvj broadcom-wl-5.100.138.tar.bz2
sudo b43-fwcutter -w /lib/firmware broadcom-wl-5.100.13
I did follow the commands on the link provided, but only one works the other two show the following:
tar (child): Error is not recoverable: exiting now tar: Child returned status 2 tar: Error is not recoverable: exiting now
e@e-HP-530-Notebook-PC-GU327AA-ABU:~$ sudo b43-fwcutter -w /lib/firmware broadcom-wl-5.100.138/linux/wl_apsta.o
[sudo] password for e:
Cannot open input file broadcom-wl-5.100.138/linux/wl_apsta.o e
The system Im using is 32bit using ubuntu 16.04 LTS.
The first one works, the next two bring as a result the above.
Can someone please help with this issue?still wifi doesnt even appear on this laptop.there is a button for the wifi which works immediately on windows but not linux ubuntu.
one update is :
e@e-HP-530-Notebook-PC-GU327AA-ABU:~$ e@e-HP-530-Notebook-PC-GU327AA-ABU:~$ sudo dpkg -i b43-fwcutter_019-2_i386.deb (Reading database ... 60% (Reading database ... 214436 files and directories currently installed.) Preparing to unpack b43-fwcutter_019-2_i386.deb ... Unpacking b43-fwcutter (1:019-2) over (1:019-2) ... Setting up b43-fwcutter (1:019-2) ... Processing triggers for man-db (2.7.5-1) ... e@e-HP-530-Notebook-PC-GU327AA-ABU:~$ e@e-HP-530-Notebook-PC-GU327AA-ABU:~$
also I dont know how to find which specific sub-model of HP 530 is it.
