I want to reinstall ubuntu (or maybe a different distro) to a new hard drive. I have the home folder backed-up using dejavu. I have the following questions:
When I reinstall ubuntu, and restore the home folder, will my apps be there too? Or will I have to reinstall everything and the configuration of each app will be there because I restored the home folder?
I use dpkg to export list of installed apps. I run it as part of my regular rsync script so backup has latest list.
From old install
dpkg --get-selections > ~/my-packages
From New install
sudo dpkg --set-selections < my-packages
sudo apt-get -y update
sudo apt-get dselect-upgrade
IF you get this error: dpkg: warning: package not in database
sudo apt-get install dselect
sudo dselect
   -> Update
   -> Install
Also how to list applications you installed. http://askubuntu.com/questions/17823/how-to-list-all-installed-packages
http://askubuntu.com/questions/464701/find-out-what-packages-were-installed-after-os-install
But do not just import all sources as that can lead to issues of versions:
http://askubuntu.com/questions/2038/backup-software-sources
oldfred
  • 12,583
The /home folder contains [usually] your personal files (documents, pictures, music, video clips ...) and your settings (tweaks).
But the apps, (application programs) that you have installed (and that do not belong to the basic installation) are stored elsewhere. They are not included in a backup of the /home folder or partition.
If you restore the home partition into your current system, the apps will not be affected, but if you create a new system, and use the backup to create your /home folder or partition, you have to install new versions of the apps.
sudodus
  • 47,684
