Using the program Baobab, I spotted that I had a file that was gigantic: ~/.cache/checkbox/checkbox.log, 8 GB large. In the same folder, I have also a 360 MB large file called subunit.log.
What is it? Why is it so large? Can I remove it or reduce its size?
Agmenor
  • 16,394
Checkbox is a program to run automatic hardware tests and report problems. It is called "System Test" in the unity dash / applications menu. You must have run it at some point. This file contains the log of the process, which appears to include a lot of details in your case. This file, and anything inside ~/.cache for that matter, can be safely deleted.
pablomme
  • 5,870
You can safely delete it, for it will be recreated automatically, starting pilling up data from start. There is already a bug report about it on launchpad about its default size limit.
You may also change the log level to error only, which will reduce the frequency of writes.
checkbox-gtk -W /usr/share/checkbox/data/whitelists/default.whitelist --log-level=error
