I have a similar problem to the one mentioned here: Unable to free up space in df but I can not reboot (I have important data in the memory).
The output of df -h / is:
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 47G 45G 0 100% /
which would be fine unless it stayed like that after I removed ca 13G of data.
Cumulated size of all files in /dev/sda2 available from / is a half of its capacity:
$ sudo du -xhd 0 /
23G /
I found https://stackoverflow.com/questions/653096/how-to-free-inode-usage#9387415 but it definitely is not a problem with inodes:
$ df -hi /
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/sda2 3.0M 535K 2.5M 18% /
How can I free the space without restarting the computer (however I shall be able to hibernate it since I have more swap area than physical RAM)?
One more comment: to save the data anywhere I need to be able to write to /tmp/ (ask NumPy developers why) which is at /dev/sda2 filesystem.
